It is currently Mon Aug 11, 2025 11:12 pm
 Post subject: Question RE Abralon...
PostPosted: Wed Jan 06, 2010 3:36 pm
Greetings,
I have been looking for a place to buy Abralon pads to try out. I can only find 3 and 6" discs on the net. All my sanders are 5", as I believe (perhaps wrongly) that most common ones are. So for those who use Abralon pads, what is your setup? Do you use a 6" pad on a 5" sander or sand by hand? Any tips would be appreciated.
PostPosted: Wed Jan 06, 2010 3:46 pm
I belive Abralon only comes in 3" and 6" pads. you can get micromesh in all the micron grits. Both 6" and 5" hook and loop with holes or without, or psa at http://www.micro-surface.com
PostPosted: Wed Jan 06, 2010 3:50 pm
I use 3" pads on a small ROS, but I see no reason that you could not use the 6" pads on a 5" sander. The unsecured portion would basically float around and do little sanding, but that wouldn't hurt anything. Or you could easily cut the disks down to a 5" diameter with scissors.
PostPosted: Wed Jan 06, 2010 6:26 pm
Last Name: Nowicki
City: Mequon
State: WI
Zip/Postal Code: 53092
I use 6" pads on a 5" ROS and they work great
John Nowicki
Users browsing this forum: No registered users and 43 guests
